深入理解 hello world 例程
py32f030-hal
crate 为 py32f030 芯片的外设支持库, 提供基本的外设访问接口。程序的运行环境为Py32_Rust_Dev开发板 。
py32f030-hal
crate 的目录结构如下:
➜ py32f030-hal git:(main) ✗ tree -L 1
├── Cargo.lock
├── Cargo.toml
├── Embed.toml
├── LICENSE
├── README.md
├── examples
├── memory.x
└── src
初次学习时,该目录中有以下几个目录或文件需要了解:
Cargo.toml
该文件为 crate 的包管理文件,通过 toml 文件格式设置 crate 的基本信息,常用属性如下
- crate 版本
- 包名
- 依赖
- features
- 编译属性
Rust 编译的最小单位为 crate,发布的单位也为 crate。通常 crate 分为两种,
- 二进制 crate:直接编译成可执行的二进制,将包含一个 main 函数入口
- 库 crate,提供库接口,编译后为 lib 文件。也可添加多个 example 用来提供接口使用样例,可在 example 文件中包含 main 函数用于直接生成可执行的测试固件。
详细可参考:TOML 格式详解
[package]
name = "py32f030_hal"
version = "0.1.0"
edition = "2021"
# See more keys and their definitions at https://doc.rust-lang.org/cargo/reference/manifest.html
[dependencies]
bare-metal = { version = "1.0.0" }
cast = "0.3"
cortex-m-rt = "0.7"
critical-section = { version = "1.1.2" }
embedded-hal = { version = "0.2", features = ["unproven"] }
embedded-hal-async = { version = "1.0" }
[features]
default = ["example"] # "embassy"
example = ["dep:defmt", "dep:defmt-rtt", "dep:panic-probe", "dep:panic-halt"]
embassy = [
"dep:embassy-executor",
"dep:embassy-sync",
"dep:embassy-time",
"time-driver",
## Enable the timer for use with `embassy-time` with a 1KHz tick rate.
time-driver = ["dep:embassy-time-driver", "embassy-time-driver/tick-hz-1_000"]
[dev-dependencies]
[[example]]
name = "blinky"
[profile.dev]
codegen-units = 1
opt-level = "z"
lto = "fat"
debug = true
overflow-checks = true
strip = false
[profile.release]
codegen-units = 1
opt-level = "z"
lto = true
debug = false
overflow-checks = false
# strip = true # 开启后release模式的日志不会显示
Embed.toml
Embed.toml
是 cargo 插件 cargo-flash
工作依赖的文件,通常来说并不是 Rust crate 中所必备的文件,在嵌入式开发中通常可以用来使用插件命令 cargo embed
来快速编译、运行、或调试固件。详细可了解:cargo-embed
➜ py32f030-hal git:(main) ✗ cat Embed.toml
[default.general]
chip = "PY32F030x8"
[default.rtt]
enabled = false
[default.gdb]
enabled = true
[default.reset]
halt_afterwards = true
在以上代码中则指定命令 cargo embed
执行时所依赖的芯片名, 重启后进入 GDB 状态。
Examples
该目录用来存放一些测试样例代码,如 blinky,uart 等,初学者可以通过运行这些测试代码来快速了解如何使用外设驱动,crate 根目录下直接执行: cargo r --example expample_file_name
➜ py32f030-hal git:(main) ✗ tree -L 1 examples
examples
├── adc_block.rs
├── advanced_timer_block.rs
├── hello_world.rs
├── i2c_master_block.rs
├── key.rs
├── rtc_block.rs
└── uart.rs
memory.x
memory.x
文件用来指定芯片 RAM 和 Flash 等存储器的大小和地址,类似 C 中的链接脚本 ld
文件。在本 crate 中非必需,目前仅当使用 example 时才会用到该文件。在自己新建的 bin crate 工程中需要包含芯片对应 memory.x 文件。
MEMORY
FLASH : ORIGIN = 0x08000000, LENGTH = 64K
RAM : ORIGIN = 0x20000000, LENGTH = 8K
在 memory.x
脚本中可以看到,
- Flash 的起始地址:0x08000000, 大小为 64K
- RAM 的起始地址:0x20000000, 大小为 8K
src
src
目录为该库的源文件,通常在单片机外设库中,每个外设作为一个单独的模块。模块的根节点在 lib.rs 中,模块名即为包名,也就是 py32f030_hal
➜ py32f030-hal git:(main) ✗ tree -L 1 src
src
├── lib.rs
├── adc
├── rtc
├── spi
├── syscfg
├── timer
└── usart
main 函数
对于大多数嵌入式工程来说,因 flash 和 ram 资源有限,无法容纳标准 std
接口的代码 ,因此需要指定 rust 引用 非标准库(no_std)。
hello-world.rs 代码如下:
#![no_std]
#![no_main]
use py32f030_hal as _;
use {defmt_rtt as _, panic_probe as _};
#[cortex_m_rt::entry]
fn main_fun() -> ! {
defmt::info!("hello world");
loop {
cortex_m::asm::wfe();
文件的 前行代码是 Rust 语言的属性宏,用于指定编译时的特定行为。感叹号 !代表该属性在整个 crate 生效。
#![no_std]
: 这个属性宏告诉 Rust 编译器在编译目标程序时不使用标准库(std
)。标准库提供了很多常用的功能,比如文件I/O、错误处理、集合类型等。不使用标准库通常意味着你需要自己提供这些功能,或者使用其他库来替代。#![no_main]
: 这个属性宏告诉 Rust 编译器不自动生成main
函数。在 Rust 中,main
函数是程序的入口点。如果你不使用这个属性宏,编译器会自动寻找一个返回()
类型的main
函数。如果你使用了这个属性宏,你需要自己提供一个#[entry]
属性的函数作为程序的入口点。也就是说,应用程序的入口函数名可以不为main
第4行 use py32f030_hal as _;
引用入本 py32f030_hal.第5行引入 defmt_rtt
和 panic_probe
第6行 #[cortex_m_rt::entry]
的属性宏将告诉编译起后面的函数名将作为程序入口。
第8行 fn main_fun() -> !
表明函数 main_fun 将永不返回。这样设计避免编译检查警告。
第9 行 defmt::info!("hello world");
该语句将会在终端中打印字符串。然后系统进入停止模式。
编译
通过命令:cargo b --example hello_world
编译程序。首次编译可能耗时较长。
➜ py32f030-hal git:(main) ✗ cargo b --example hello_world
warning: unused manifest key: dependencies.embedded-io-async.option
Compiling proc-macro2 v1.0.85
Compiling unicode-ident v1.0.12
Compiling version_check v0.9.4
Compiling syn v1.0.109
Compiling semver-parser v0.7.0
Compiling nb v1.1.0
Compiling cortex-m v0.7.7
Compiling void v1.0.2
Compiling nb v0.1.3
Compiling thiserror v1.0.61
Compiling critical-section v1.1.2
Compiling embedded-hal v0.2.7
Compiling semver v1.0.23
Compiling semver v0.9.0
Compiling defmt v0.3.8
Compiling rustc_version v0.2.3
Compiling proc-macro-error-attr v1.0.4
Compiling proc-macro-error v1.0.4
Compiling autocfg v1.3.0
Compiling bare-metal v0.2.5
Compiling num-traits v0.2.19
Compiling ident_case v1.0.1
Compiling byteorder v1.5.0
Compiling vcell v0.1.3
Compiling fnv v1.0.7
Compiling defmt-macros v0.3.9
Compiling az v1.2.1
Compiling volatile-register v0.2.2
Compiling quote v1.0.36
Compiling syn v2.0.66
Compiling bitfield v0.13.2
Compiling cortex-m-rt v0.7.3
Compiling atomic-polyfill v1.0.3
Compiling rustc_version v0.4.0
Compiling bitflags v1.3.2
Compiling panic-probe v0.3.2
Compiling defmt-rtt v0.4.1
Compiling ssd1309 v0.3.0
Compiling heapless v0.7.17
Compiling PY32f030xx-pac v0.1.0
Compiling display-interface v0.4.1
Compiling embedded-io-async v0.6.1
Compiling embedded-hal-async v1.0.0
Compiling embassy-hal-internal v0.1.0
Compiling gcd v2.3.0
Compiling fugit v0.3.7
Compiling embedded-graphics-core v0.3.3
Compiling float-cmp v0.8.0
Compiling darling_core v0.20.9
Compiling hash32 v0.2.1
Compiling micromath v1.1.1
Compiling stable_deref_trait v1.2.0
Compiling embedded-hal v1.0.0
Compiling embedded-io v0.6.1
Compiling embedded-graphics v0.7.1
Compiling fugit-timer v0.1.3
Compiling display-interface-i2c v0.4.0
Compiling embassy-futures v0.1.1
Compiling panic-halt v0.2.0
Compiling bare-metal v1.0.0
Compiling cast v0.3.0
Compiling drop-move v0.1.0
Compiling cortex-m-rt-macros v0.7.0
Compiling thiserror-impl v1.0.61
Compiling darling_macro v0.20.9
Compiling darling v0.20.9
Compiling enumset_derive v0.10.0
Compiling enumset v1.1.5
Compiling defmt-parser v0.3.4
Compiling py32f030_hal v0.1.0 (/Users/hunter/mywork/py32/py32f030-hal)
Finished `dev` profile [optimized + debuginfo] target(s) in 38.96s
编译完成后生成的 elf 文件路径为:
- Debug模式:
target/thumbv6m-none-eabi/debug/examples/hello_world
- Release模式:
常使用size 命令查看 flash 和 ram 占用情况。
arm-none-eabi-size target/thumbv6m-none-eabi/debug/examples/hello_world
text data bss dec hex filename
6344 56 1032 7432 1d08 target/thumbv6m-none-eabi/debug/examples/hello_world
在默认情况下,Debug 模式可能会占用较多的空间,但通常在 Release 模式下,则会减少很多。由于目前使用了 defmt
作为打印接口,因此会占用较多资源,如果资源限制,可选用其他占用较少的 crate。
查看汇编
elf 文件转汇编语言通过命令:arm-none-eabi-objdump -d target/thumbv6m-none-eabi/debug/examples/hello_world > debug.asm
target/thumbv6m-none-eabi/debug/examples/hello_world: file format elf32-littlearm
Disassembly of section .text:
080000bc :
80000bc: f000 fe25 bl 8000d0a
80000c0: 4808 ldr r0, [pc, #32] ; (80000e4 )
80000c2: 4909 ldr r1, [pc, #36] ; (80000e8 )
80000c4: 2200 movs r2, #0
80000c6: 4281 cmp r1, r0
80000c8: d001 beq.n 80000ce
80000ca: c004 stmia r0!, {r2}
80000cc: e7fb b.n 80000c6
80000ce: 4807 ldr r0, [pc, #28] ; (80000ec )
80000d0: 4907 ldr r1, [pc, #28] ; (80000f0 )
80000d2: 4a08 ldr r2, [pc, #32] ; (80000f4 )
80000d4: 4281 cmp r1, r0
80000d6: d002 beq.n 80000de
80000d8: ca08 ldmia r2!, {r3}
80000da: c008 stmia r0!, {r3}
80000dc: e7fa b.n 80000d4
80000de: f000 f895 bl 800020c
80000e2: de00 udf #0
80000e4: 20000038 .word 0x20000038
80000e8: 20000040 .word 0x20000040
80000ec: 20000000 .word 0x20000000
80000f0: 20000038 .word 0x20000038
80000f4: 080018c8 .word 0x080018c8
0800020c :
800020c: b580 push {r7, lr}
800020e: af00 add r7, sp, #0
8000210: f000 f800 bl 8000214 <_ZN11hello_world22__cortex_m_rt_main_fun17h27b2c8ae827133dbE>
08000214 <_ZN11hello_world22__cortex_m_rt_main_fun17h27b2c8ae827133dbE>:
8000214: b580 push {r7, lr}
8000216: af00 add r7, sp, #0
8000218: f000 febe bl 8000f98 <_defmt_acquire>
800021c: 4803 ldr r0, [pc, #12] ; (800022c <_ZN11hello_world22__cortex_m_rt_main_fun17h27b2c8ae827133dbE+0x18>)
800021e: f000 fddc bl 8000dda <_ZN5defmt6export6header17hdbd91843ccf33f48E>
8000222: f000 fee5 bl 8000ff0 <_defmt_release>
8000226: bf20 wfe
8000228: e7fd b.n 8000226 <_ZN11hello_world22__cortex_m_rt_main_fun17h27b2c8ae827133dbE+0x12>
800022a: 46c0 nop ; (mov r8, r8)
800022c: 00000003 .word 0x00000003
细心的读者可以看到汇编的 main 函数里面最终调用了函数 _ZN11hello_world22__cortex_m_rt_main_fun17h27b2c8ae827133dbE
, 与我们定义的
fn main_fun() -> !
Rust 源码编译后的函数和变量符号变化规律与C++相似,变量在编译后的名字通常按照一定规律进行 manging(名字改编),确保在链接阶段能够正确识别和处理符号,因此模板变量、不同作用域的变量可以允许相同名字。
如果在编写代码时为避免函数名被重命名,可以使用属性#[no_mangle]
标记避免重命名。通常在以下场景被使用:
- 其他语言绑定,如调用C的函数或变量, 确保接口兼容
- 提供接口给其他语言,如汇编等
- 动态库开发
查看符号信息
通常使用 arm-none-eabi-readelf 命令查看编译后的固件的指令格式,大小端,CPU架构,段信息,如中断向量表的偏移、各信息段的大小,方便了解固件各段的具体大小,为优化固件大小提供重要信息。
➜ py32f030-hal git:(main) ✗ arm-none-eabi-readelf target/thumbv6m-none-eabi/debug/examples/hello_world -A
Attribute Section: aeabi
File Attributes
Tag_conformance: "2.09"
Tag_CPU_arch: v6S-M
Tag_CPU_arch_profile: Microcontroller
Tag_ARM_ISA_use: No
Tag_THUMB_ISA_use: Thumb-1
Tag_ABI_PCS_R9_use: V6
Tag_ABI_PCS_GOT_use: direct
Tag_ABI_FP_denormal: Needed
Tag_ABI_FP_exceptions: Needed
Tag_ABI_FP_number_model: IEEE 754
Tag_ABI_align_needed: 8-byte
Tag_ABI_align_preserved: 8-byte, except leaf SP
Tag_CPU_unaligned_access: None
Tag_ABI_FP_16bit_format: IEEE 754
➜ py32f030-hal git:(main) ✗ arm-none-eabi-readelf target/thumbv6m-none-eabi/debug/examples/hello_world -S
There are 22 section headers, starting at offset 0x5ef20:
Section Headers:
[Nr] Name Type Addr Off Size ES Flg Lk Inf Al
[ 0] NULL 00000000 000000 000000 00 0 0 0
[ 1] .vector_table PROGBITS 08000000 010000 0000bc 00 A 0 0 4
[ 2] .text PROGBITS 080000bc 0100bc 001d98 00 AX 0 0 4
[ 3] .rodata PROGBITS 08001e54 011e54 000738 00 AM 0 0 4
[ 4] .data PROGBITS 20000000 020000 000040 00 WA 0 0 8
[ 5] .gnu.sgstubs PROGBITS 080025e0 020040 000000 08 A 0 0 32
[ 6] .bss NOBITS 20000040 020040 000140 00 WA 0 0 8
[ 7] .uninit NOBITS 20000180 020040 000400 00 WA 0 0 4
[ 8] .defmt PROGBITS 00000000 020040 000006 00 0 0 1
[ 9] .debug_loc PROGBITS 00000000 020046 0036a7 00 0 0 1
[10] .debug_abbrev PROGBITS 00000000 0236ed 000f37 00 0 0 1
[11] .debug_info PROGBITS 00000000 024624 0121c5 00 0 0 1
[12] .debug_aranges PROGBITS 00000000 0367e9 000bd0 00 0 0 1
[13] .debug_ranges PROGBITS 00000000 0373b9 002018 00 0 0 1
[14] .debug_str PROGBITS 00000000 0393d1 01bd34 01 MS 0 0 1
[15] .comment PROGBITS 00000000 055105 000048 01 MS 0 0 1
[16] .ARM.attributes ARM_ATTRIBUTES 00000000 05514d 000030 00 0 0 1
[17] .debug_frame PROGBITS 00000000 055180 000d1c 00 0 0 4
[18] .debug_line PROGBITS 00000000 055e9c 00632f 00 0 0 1
[19] .symtab SYMTAB 00000000 05c1cc 001200 10 21 218 4
[20] .shstrtab STRTAB 00000000 05d3cc 0000dd 00 0 0 1
[21] .strtab STRTAB 00000000 05d4a9 001a76 00 0 0 1
Key to Flags:
W (write), A (alloc), X (execute), M (merge), S (strings), I (info),
L (link order), O (extra OS processing required), G (group), T (TLS),
C (compressed), x (unknown), o (OS specific), E (exclude),
y (purecode), p (processor specific)
如上所示,可以看到中断向量表 vector_table
的地址为 0x08000000
, data
段的起始地址为 0x20000000
, 与 memory.x
定义的一致。
