These devices are designed to limit overvoltages for the common telecommunication line of communication, computer and consumer products. Overvoltages are normally caused by a.c. power system or lightning flash disturbances which are induced or conducted on to the common products. A single device provides 2-point protection and is typically used for the protection of 2-wire telecommunication equipment (e.g. between the Ring and Tip wires for telephones and modems). Combinations of devices can be used for multi-point protection (e.g. 3-point protection between Ring, Tip and Ground).
The protector consists of a symmetrical voltage-triggered bi-directional sidac. Overvoltages are initially clipped by breakdown clamping until the voltage rises to the breakover level, which causes the devices to crowbar into a low-voltage on state. This low-voltage on state causes the current resulting from the overvoltage to be safely diverted through the device. The high crowbar holding current prevents d.c. latchup as the diverted current subsides. These protectors are guaranteed to voltage limit and withstand the listed lightning surges in both polarities.
感谢啊!请帮忙翻译下面这几句!!!
全部回复(8)
这些装置设计用于限制通信设施、计算机和消费品通用电讯线的过电压.过电压通常由交流电系统或在通用品上感应名传导的闪电干扰造成.一个单独的装置提供2点保护,有代表性地是用作2线电讯设备(例:电话和调制解调器(猫)用的振铃和尖塞[ring and tip]电线)的保护.装置结合使用可以用于多点保护(例:在接地/振铃/尖塞[ring/tip/ground]三线间的三点保护).
保护器由一个匀称电压触发型双向交流二极管组成,过电压最初被弱钳位剪除址到电压上升至超过的级别,该级别会造成装置进入一个低电压开启状态.该低电压开启状态那个造成过电压引起的电流安全地转移开.强消弧控制电流防止了直流闭锁,因为转移开的电流衰减了.这些保护器保证了电压限制且承受得了在两极的雷电冲击.(仅供参考)
@rubypan
这些装置设计用于限制通信设施、计算机和消费品通用电讯线的过电压.过电压通常由交流电系统或在通用品上感应名传导的闪电干扰造成.一个单独的装置提供2点保护,有代表性地是用作2线电讯设备(例:电话和调制解调器(猫)用的振铃和尖塞[ringandtip]电线)的保护.装置结合使用可以用于多点保护(例:在接地/振铃/尖塞[ring/tip/ground]三线间的三点保护).保护器由一个匀称电压触发型双向交流二极管组成,过电压最初被弱钳位剪除址到电压上升至超过的级别,该级别会造成装置进入一个低电压开启状态.该低电压开启状态那个造成过电压引起的电流安全地转移开.强消弧控制电流防止了直流闭锁,因为转移开的电流衰减了.这些保护器保证了电压限制且承受得了在两极的雷电冲击.(仅供参考)
这些装置设计用于限制通信设施、计算机和消费品通用电讯线的过电压.过电压通常由交流电系统或在通用品上感应或传导的闪电干扰造成.一个单独的装置提供"两点"保护,有代表性地是用作2线电讯设备(例:电话和调制解调器(猫)用的振铃和尖塞[ring and tip]电线)的保护.装置结合使用可以用于多点保护(例:对接地/振铃/尖塞[ring/tip/ground]三线的"三点"保护).
@rubypan
这些装置设计用于限制通信设施、计算机和消费品通用电讯线的过电压.过电压通常由交流电系统或在通用品上感应或传导的闪电干扰造成.一个单独的装置提供"两点"保护,有代表性地是用作2线电讯设备(例:电话和调制解调器(猫)用的振铃和尖塞[ringandtip]电线)的保护.装置结合使用可以用于多点保护(例:对接地/振铃/尖塞[ring/tip/ground]三线的"三点"保护).保护器由一个匀称电压触发型双向交流二极管组成,过电压最初被弱钳位剪除址到电压上升至超过的级别,该级别会造成装置进入一个低电压开启状态.该低电压开启状态那个造成过电压引起的电流安全地转移开.强消弧控制电流防止了直流闭锁,因为转移开的电流衰减了.这些保护器保证了电压限制且承受得了在两极的雷电冲击.(仅供参考)
感谢!似乎不是太明白?
