One questione need one who can help me to confirm:
we have one itme energy saving ligthing product,It was used PLC 10w and equiped with a ballast,it means the product its temp will very lower at its shade position,( this is floor lamp its height 1.8M),when i do bleow simple test to check its resistance to fire :
i used the igniter to lit the plastic shade and found the shade continuosely burned.
From EN 60598-1 says the non-metalic parts contain current parts or protect elctric shock then need comply with"resistance to fire" but this shade it looks NOT act as above two functions.
And from EN 60335-1 it was diffrently said as EN 60598 it was said if it was non-metal parts should compy with "resistance to fire"
i am think this shade parts need comply with "resistance to fire".how do all of you think???????
Need comply with
全部回复(22)
@terry.feng
isee.thelampshadelikeachimney,isn'tit?ithinkthispartnowanttocomply.thisismyidea..
Thanks a lot.
yes.from IEC 60598-1, It seems ok.
i am not understand why IEC 60335-1 was strict than iec 60598-1 for this "resistance to fire" issue.
as you know iec 60335-1 sais "all non-metalic enclosure need resistance to fire.........."
@superjohnyao
Thanksalot.yes.fromIEC60598-1,Itseemsok.iamnotunderstandwhyIEC60335-1wasstrictthaniec60598-1forthis"resistancetofire"issue.asyouknowiec60335-1sais"allnon-metalicenclosureneedresistancetofire.........."
其实598是有很多不足或严谨的地方,这是行业内公认的,不然会有这么多CTL决议啊,但耐火这条我个人认为并不是比335不严谨,598只是根据不同灯具产品有相应的不同要求,应急灯就是一个好例子.有些灯的灯罩作用偏向于一个装饰物,不必符合耐火试验,反而我觉得它这点比家电标准灵活点.
@terry.feng
是2类灯具吧?要看灯杯是否与一些电原线的基本绝缘触及,若是碰到基本绝缘物件的话就要做650灼热丝,还要进行耐热试验75或相应的温升+25度——————个人理解标准的看法.我想问问你起初是否做ul产品的?
Terry.feng:
谢谢你的评论.我当时就放货了.因为我发现这两部分都不是IEC60598-1 说的"起防护触电,里面含有带电体的非铁部件".而且节能灯温度很低,这两部分不可能由于产品短路而起火.
我怀疑是因为我发现IEC 60335-1 里面说的"非铁部件外壳要RESISTANCE TO FIRE" 而且UL 产品好象也有次要求.所以我想是不是要求产品外壳防火不但是可以防止产品短路而起火和如果产品周围起火的话也可以防止燃烧到产品本身.因而可以防止燃烧到电气等以降低灾害的蔓延?我个人看法
