1 Features
Multiple Device Access (MDA):Global Read/Write OperationsI2C™ and SMBus™-Compatible InterfaceResolution: 8 Bits3 DescriptionThe ZCC103 is a digital output temperature sensor ina four-ball wafer chip-scale package (WCSP). TheZCC103 is capable of reading temperatures to aresolution of 1°C.The ZCC103 features a two-wire interface that iscompatible with both I2C and SMBus interfaces. Inaddition, the interface supports multiple deviceaccess (MDA) commands that allow the master tocommunicate with multiple devices on the bussimultaneously, eliminating the need to sendindividual commands to each ZCC103 on the bus.Up to eight ZCC103s can be tied together in paralleland easily read by the host. The ZCC103 isespecially suitable for space-constrained, power-sensitive applications with multiple temperaturemeasurement zones that must be monitored.The ZCC103 is specified for operation over atemperature range of –40°C to 125°C.Device Information(1)Accuracy: ±1°C Typical (–10°C to 100°C)Low Quiescent Current:3-μAActiveIQ at0.25Hz1-μA ShutdownSupply Range: 1.4 V to 3.6 VDigital Output
