GENERAL DESCRIPTION
OB2263 is a highly integrated current mode PWM
control IC optimized for high performance, low
standby power and cost effective offline flyback
converter applications in sub 30W range.
PWM switching frequency at normal operation is
externally programmable and trimmed to tight range.
At no load or light load condition, the IC operates in
extended ‘burst mode’ to minimize switching loss.
Lower standby power and higher conversion
efficiency is thus achieved.
VDD low startup current and low operating current
contribute to a reliable power on startup design with
OB2263. A large value resistor could thus be used in
the startup circuit to minimize the standby power.
The internal slope compensation improves system
large signal stability and reduces the possible sub-
harmonic oscillation at high PWM duty cycle output.
Leading-edge blanking on current sense(CS) input
removes the signal glitch due to snubber circuit diode
reverse recovery and thus greatly reduces the external
component count and system cost in the design.
OB2263 offers complete protection coverage with
automatic self-recovery feature including Cycle-by-
Cycle current limiting (OCP), over load protection
(OLP), VDD over voltage clamp and under voltage
lockout (UVLO). The Gate-drive output is clamped
to maximum 18V to protect the power MOSFET.
Excellent EMI performance is achieved with On-
Bright proprietary frequency shuffling technique
together with soft switching control at the totem pole
gate drive output.
Tone energy at below 20KHZ is minimized in the
design and audio noise is eliminated during operation.
OB2263 is offered in SOT23-6, SOP-8 and DIP-8
packages.
FEATURES
On-Bright Proprietary Frequency Shuffling
Technology for Improved EMI Performance.
Extended Burst Mode Control For Improved
Efficiency and Minimum Standby Power Design
Audio Noise Free Operation
External
Programmable PWM Switching
Frequency
Internal Synchronized Slope Compensation
Low VDD Startup Current and Low Operating
Current (1.4mA)
Leading Edge Blanking on Current Sense Input
Good Protection Coverage With Auto Self-
Recovery
o
VDD Over Voltage Clamp and Under Voltage
Lockout with Hysteresis (UVLO)
o
Gate Output Maximum Voltage Clamp (18V)
o
On-Bright Proprietary Line Input Compensated
Cycle-by-Cycle Over-current Threshold Setting
For Constant Output Power Limiting Over
Universal Input Voltage Range.
o
Overload Protection (OLP
深圳市华钻电子有限公司成立于2004年,位于广东省深圳市,同时还分别下设有中山、宁波和西安分公司,是一家代理及分销国内外各大品牌电元器件的电子科技公司,具有丰富的电子行业经验,所供应的产品应用于LED照明,LED显示,LED电源,LED模组,通讯,无线充电及航天航空电子产品领域。代理及分销品牌有:亚成微,绿达 长运通,台湾聚积 台湾茂达 明微 等 MOS 新洁能 威兆 瑞森 美浦森 欢迎来电咨询 13823198522 微微
