适用于隔离式电源的变压器驱动器ZCC6601 替代SN6505
DESCRIPTION
The ZCC6601 is a monolithic oscillator/power-driver, specifically designed for small form factor, isolated power supplies in isolated interface applications. It drives a low-profile, center-tapped transformer primary from a 3.3 Vor 5 V DC power supply. The secondary can be wound to provide any isolated voltage based on transformerturns ratio.
The ZCC6601 consists of an oscillator followed by a gate drive circuit that provides the complementary output signals to drive the ground referenced N-channel power switches. The internal logic ensures break-before-make action between the two switches.
The ZCC6601 is available in a small SOT23-5 package, and is specified for operation at temperatures from –40°C to 125°C.
FEATURES
Push-Pull Driver for Small Transformers Single 3.3 V or 5 V Supply High Primary-side Current Drive:
– 5 V Supply: 650 mA (max)
– 3.3 V Supply: 450 mA (max)
Low Ripple on Rectified Output Permits Small
Output Capacitors
Soft start and Current limit Thermal shutdown Small 5-pin SOT23 Package Short circuit protection Over temperature protection
APPLICATIONS
Isolated Interface Power Supply for CAN, RS-
485, RS-422, RS-232, SPI, I2C, Low-Power LAN
Industrial Automation Process Control Medical Equipment
全部回复(0)
