深圳市芯美力科技有限公司,
宝砾微一级代理
qq354191130
20V, 10A, Synchronous Boost Converter with Load Disconnect Control
DS-PL30502-Rev. 1.0
www.powlicon.com
1 of 17
2018-11-03
© Powlicon Inc.
1 Features
Input Voltage Range :2.7V to 20V
Output Voltage Range: 4.5V to 20V
Efficiency up to 96%: VIN = 7.2 V, VBUS = 16 V,
IOUT = 2 A
Two 7mΩ FETs Integrated
Adjustable switching frequency up to 2.2MHz
Programmable Cycle-by-Cycle Current Limit up to
15A
Hiccup Short Protection with Load Disconnect Drive
DCM Operation under light load
Input Under-Voltage Lockout
Output Over-Voltage Protection at fixed 21V
Over-Temperature Protection
QFN13-FC 3*3.5 Package
2 Applications
Portable POS terminal
Bluetooth Speaker
E-Cigarette
Thunderbolt Interface
USB Type-C Power Delivery
3 Description
The PL30502 is a 20-V synchronous Boost converter with
the gate driver built-in for load disconnect. The PL30502
integrates two low on resistance power FETs: A 7-mΩ
switching FET and a 7-mΩ rectifier FET.
The PL30502 uses the adaptive constant off time peak
current mode control. PL30502 has an internal feature to
help improving light load efficiency. When output current is
low, PL30502 will go into DCM mode.
The PL30502 includes configurable features include
programmable
cycle-by-cycle
current
limit
and
programmable switching frequency functions.
The PL30502 could isolate the output from input side when
shutdown. Once the output is shorted, it enters into the
hiccup mode to lower the thermal stress and can recover
automatically after the short condition releases.
Additionally, the PL30502 also has OVP and thermal
protection to avoid the fault operation. The PL30502 is in a
3.0-mm x 3.5-mm 13-pin VQFN package with enhanced
thermal dissipation.
