想用TIDA-00570 High Speed DLP Sub-system DLPC910 Main Board 测试下载一个呼吸灯程序,确定FPGA能否跑起来,但是ise一直下载失败。
报错信息如下:Reading E:/ISE14.7/14.7/ISE_DS/ISE/virtex5/data/xc5vlx30.bsd...INFO:iMPACT:501 - '1': Added Device xc5vlx30 successfully.--------------------------------------------------------------------------------------------------------------------------------------------'1': : Manufacturer's ID = Xilinx xcf16p, Version : 13INFO:iMPACT:1777 -Reading E:/ISE14.7/14.7/ISE_DS/ISE/xcfp/data/xcf16p.bsd...INFO:iMPACT:501 - '1': Added Device xcf16p successfully.--------------------------------------------------------------------------------------------------------------------------------------------'2': : Manufacturer's ID = Xilinx xc5vlx30, Version : 6INFO:iMPACT:501 - '1': Added Device xc5vlx30 successfully.--------------------------------------------------------------------------------------------------------------------------------------------'3': : Manufacturer's ID = Xilinx xcf16p, Version : 13INFO:iMPACT:501 - '1': Added Device xcf16p successfully.--------------------------------------------------------------------------------------------------------------------------------------------done.PROGRESS_END - End Operation.Elapsed time = 1 sec.'2': Loading file 'D:/porject3/top1.bit' ...done.INFO:iMPACT:2257 - Startup Clock has been changed to 'JtagClk' in the bitstream stored in memory,but the original bitstream file remains unchanged.UserID read from the bitstream file = 0xFFFFFFFF.----------------------------------------------------------------------INFO:iMPACT:501 - '2': Added Device xc5vlx30 successfully.--------------------------------------------------------------------------------------------------------------------------------------------INFO:iMPACT - Current time: 2019/7/25 9:46:13PROGRESS_START - Starting Operation.Maximum TCK operating frequency for this device chain: 15000000.Validating chain...Boundary-scan chain validated successfully.2: Device Temperature: Current Reading: -273.00 C2: VCCINT Supply: Current Reading: 0.000 V2: VCCAUX Supply: Current Reading: 0.000 V4: Device Temperature: Current Reading: -273.00 C4: VCCINT Supply: Current Reading: 0.000 V4: VCCAUX Supply: Current Reading: 0.000 VINFO:iMPACT - Failed to initialize the virtex5 device.'2': Programming device... Match_cycle = NoWait.Match cycle: NoWait LCK_cycle = NoWait.LCK cycle: NoWaitdone.INFO:iMPACT:2218 - Error shows in the status register, release done bit is NOT 1.INFO:iMPACT:2219 - Status register values:INFO:iMPACT - 0000 0000 0000 0000 0000 0000 0000 0000INFO:iMPACT:579 - '2': Completed downloading bit file to device.INFO:iMPACT:188 - '2': Programming completed successfully. Match_cycle = NoWait.Match cycle: NoWait LCK_cycle = NoWait.LCK cycle: NoWaitINFO:iMPACT - '2': Checking done pin....done.'2': Programming terminated. DONE did not go high.PROGRESS_END - End Operation.Elapsed time = 53 sec.报错信息
