ET2104是一款高性能可配置的双向电1 51124 76010莫 先 生压双电源转换器。在广泛的输入和输出电压电平范围内转换。ET2104还可以在推挽式中工作。环境。它用于I2C总线兼容主设备和从设备之间的电压转换器。提供内部10kΩ上拉电阻。该设备的设计使得A端口跟踪VCCA级别,B端口跟踪VCCB级别。这允许在1.65V到5.5V的任何两个电平之间进行双向A/B端口电压转换。VCCA可以等于1.65V到5.5V的VCCB。任何一个VCC都可以先通电。如果任何一个VCC被移除,内部断电控制电路将设备置于3状态。该装置的四个端口具有自动方向感功能。任何一个端口都可以检测到输入信号,并将其作为输出信号传输到另一个端口。
General Description
The ET2104 is a high-performance configurable dual-voltage-supply translator for bi-directional voltage
translation over a wide range of input and output voltages levels. The ET2104 also works in a push-pull
environment. It is intended for use as a voltage translator between I2C-Bus compliant masters and slaves. Internal 10KΩ pull-up resistors are provided.
The device is designed so the A port tracks the VCCA level and the B port tracks the VCCB level. This allows for bi-directional A/B-port voltage translation between any two levels from 1.65V to 5.5V. VCCA can equal VCCB from1.65V to 5.5V. Either VCC can be powered-up first. Internal power-down control circuits place the device in 3-state if either VCC is removed.
The four ports of the device have automatic direction-sense capability. Either port may sense an input signal and transfer it as an output signal to the other port.
Features
● Bi-Directional Interface between Any Two Levels:1.65V to 5.5V
● No Direction Control Needed
● Internal 10K Pull-Up Resistors
● System GPIO Resources Not Required when OE tied to VCCA
● I2C-Bus Isolation
● A/B Port VOL = 175mV (Typical), VIL = 150mV, IOL = 6mA
● Open-Drain Inputs / Outputs
● Works in Push Pull Environment
● Accommodates Standard-Mode and Fast-Mode I2C-Bus Devices
● Supports I2C Clock Stretching & Multi-Master
● Fully Configurable: Inputs and Outputs Track VCC
● Non-Preferential Power-Up; Either VCC Can Power-Up First
● Outputs Switch to 3-State if Either VCC is at GND
● Tolerant Output Enable: 5V
● Packaged in SOP14(ET2104M)/TSSOP14(ET2104V)/DSBGA12(ET2104Z)/QFN14(ET2104Y)
Pin Configuration
