电机控制智能功率模块(IPM)
2016-03-30 14:04 来源: 编辑:
适用于AC100~253Vrms 电压等级的低功率马达驱动,例如冰箱,洗碗机,风扇马达,洗衣机和空调。
AC 100~253Vrms class low power motor drives like refrigerators, dishwashers, fan motors, washing machines and air-conditioners
Feature:
• Over-temperature protection (OTP) 过温保护
• Short-circuit current protection (CSC) 短路保护
v Highest Efficiency and rugged Power Module for motor drivers
v 高效且可靠的电机驱动模块
v Smallest Size for 100W~1KW motor applications
v 较小的封装尺寸,适用于100W~1KW的马达驱动
v  Built-in Temperature Monitoring and Temperature Protection
v 集成过温监控和过温保护
008
009
