前几天弄到c@dence 15,赶快下载,每个CD保留一星期,再传下一个。
内部集成了orc@d10.0,只是太大了,共3CD,1G,暂时还没弄到单独版,不知是否需要,或等单独版.
全部回复(26)
@兰波
哈哈。雪版主都想要呀。一定是好东东。恩。1G的数据应该差不多能放下,不过可能就放不了多少别的东西了。而且对于1G的大文件,如果很多人下载,对带宽的影响是非常大的。假如100个下载,就得用掉100G的带宽。给我们提供服务器的那家伙会疯了的。呵呵。我觉得可以这样:就提供一段时间给大家下载。比如1个月。可能可以。等以后有更大的空间和带宽再说。Tiny兄,好吗?辛苦了!!
PSPICE 著名的数/模混合电路仿真软件
PSPICE
模拟与混合信号仿真的行业标准
PSpice 仿真器是一个全功能的模拟和混合信号仿真器,它支持从高频系统到低功耗IC设计的任何电路。其高级功能允许用户进行“What If”分析。PSpice强大的仿真引擎目前已方便地与Orcad Capture和Concept HDL原理图输入工具结合在一起,使工程师可以方便地在单一的环境里建立设计、控制仿真及得到结果。
PSpice产品包括:PSpice Studio、PSpice、PSpice A/D、PSpice A/D Basics和PSpice Advanced Analysis Option。
PSpice Studio
Includes all the functionality of PSpice® simulator with the built-in capabilities of PSpice Advanced Analysis.
PSpice
A full-featured simulator for serious analog designers. Sophisticated, internal models allow you to simulate everything from high-frequency systems to low-power IC designs. Draw on the expansive library of models to create off-the-shelf parts, or create models for new devices. Fully explore the relationships in your design with “what if” scenarios before committing to final implementation.
PSpice A/D
A sophisticated, native mixed-signal simulator and a superset of PSpice. Allows you to simulate mixed-signal designs of any size containing analog and digital parts. This includes everything from IGBTs and pulse-width modulators to DACs and ADCs. View your simulation results in both analog and digital from the same window and on the same time axis.
PSpice A/D Basics
An entry-level, mixed-signal simulation tool ideal for simulating simple, basic analog, or basic mixed-signal designs. PSpice A/D Basics imposes no limits on circuit size and performs functional simulation of digital parts in mixed-signal simulations allowing you to perform all the basic PSpice analyses.
PSpice Advanced Analysis is a new product from Cadence featuring technology adapted from our Analog Workbench product. As an add-on option to PSpice or PSpice A/D, PSpice Advanced Analysis provides a unified environment for taking designs further – improving time-to-market performance and the overall quality of your design while keeping operating costs in check.
Pspice / Pspice A/D介绍
对于仿真技术目前最流行是是以美国伯克利分校开发的Spice为核心的仿真软件,而以Spice为核心开发的最好的仿真软件就是Orcad Pspice,它之所以流行就是因为它能很好的运行在PC平台上且能很好的进行模拟数字混合信号的仿真,而且能解决很多的设计上的实际问题。目前全世界的的仿真市场Orcad Pspice占整个市场分额的82%(数据来源Dataquest, Dataquest是世界上最具权威的市场数据统计公司);另外一种仿真软件是非Spice为核心的其他专门电路及系统级的仿真软件,它相对于Spice为核心的仿真软件能解决超大(晶体管数超过5万)规模的电路因瞬态或DC分析不收敛导致错误结果或存储器溢出等在电路中极少碰到,但又在设计理论电路中又存在问题,同时也提高了仿真速度。这样的仿真软件的价格很高其使用的平台基本上都是UNIX平台;使用非常困难。除了那些具有世界上领先开发水平的单位才会购买,一般很少有单位会为其投资。
PSPICE仿真器在1985年第一次出现后,经历了不断的增强和改造,已经被成千上万的工程师试验和证实;PSPICE是为严肃的模拟和混合信号设计而特性化的仿真器。使用其灵活的内部模型,用户可以仿真包括从高频系统到低功耗IC设计的任何模拟系统,用户可以使用数据表创建新器件的模型。
技术特点:
u 使用功能强大的Orcad Capture或者CAPTURE/CIS输入用户的设计;
u 可以方便地将PSpice原理图编辑器创建的PSpice设计导入到Orcad Capture—PSpice环境中;
u 在Orcad Capture CIS中启动交互式图形化PSpice激励编辑器,定义和预览激励特性;
u 访问可用参数描述的内置功能,或者用鼠标手工绘制分段性信号,创建任意形状的激励;
u 创建多个仿真剖面,并保存到Capture CIS的项目管理器中,用户可以再次调用,并对同一电路运和不同的仿真;
u Pspice A/D自动识别A到D和D到A连接,并插入接口了电路和电源,进行恰当的处理;
u 模拟和事件驱动数字仿真综合引擎提高了仿真的速度,而不会降低精度;
u 图示波形分析器在同一个时间轴上混合地显示模拟和数字仿真结果;
u 可直接查看节点电压、管脚电流和单个器件的功率损耗或噪声分布;
u 通过高级的参数、蒙特卡罗和最坏情况分析显示元器件变化时电路行为的改变;
u 创建绘图体模板,使用它们可以很容易地完成复杂测量,只需在原理图中期望的管脚、网络和器件上放置标志即可;
u 可以绘出电路电压、电流和功率损耗及其复杂函数,包括幅频相位伯特图和小信号特性的微分;
u 使用参数、蒙特卡罗和最坏情况分析,在多次运行中改变元件的数值,可以快速地得到一簇波形结果;
u 准确的内部模型,包括常用的R,L,C和二极管和晶体管,另外还有:内置IGBTs;7种MOSFET模型,包括工业上标准的BSIM3V3.1和EKV2.6模型;5种GaAsFET模型,包括Parker-Skellern和TriQuint TOM-2模型;带饱和性磁滞的非线性磁性模型;合并了延迟、反射、损耗、消散和串扰的传输线模型;数字元件,包括带有模拟I/O模型的双向传输门;
u 器件公式开发工具包允许建立PSPICE能够使用的新的内部模型公式;
u 模型库可能选择产自北美、日本和欧洲的16000个模拟和混合器件的模型;同时可从www.pspice.com下载大部分器件及厂家提供的Spice模型(大约有50多万个型供下载)。
u 使用带有各种宏模型的复杂器件,包括运算放大器、比较器、调节器、光耦、ADC、DAC等;
u 直接从网上下载各个厂家提供的最新器件仿真模型;
u PSPICE模型编辑器,可直观地指导用户快速实现提取过程,器件的特性曲线给用户提供快速的图形反馈;
u 使用数字行为建模创建代表内部状态和管脚到管脚延迟的布尔表达式;
u 使用PSpice优化器自动调整电路,可自动调节电路参数的数值,改善模拟电路的性能,或者将电路性能匹配到某一数据曲线;并能将参数自动后向注释到Capture环境中;
u 从标准的测量函数中选择指标,如带宽、超调、上升时间和中心频率,或者使用性能分析向导创建自定义测量函数;
u 为有经验的器件物理工作者提供器件公式开发工具包(DEDK),用来开发任何器件模型;
NC-DESKTOP SIMULATORS:
High-quality and reliable desktop simulation
Cadence Verilog® and VHDL simulation solutions, along with NC-Sim Desktop simulators bring quality and reliability to the engineer’s workbench. As full-featured versions of the world’s fastest simulator tools, Cadence NC-Sim Desktop solutions are ideal for engineering teams who want to leverage the performance and capacity created to validate multi-million gate designs. For more than a decade, Cadence simulators have served as the standard in the electronic design and product industry. To date, close to 50,000 designs have been successfully completed using Cadence simulators
很好的Verilog/VHDL仿真工具,其中NC-Verilog 的前身是著名的Verilog仿真软件:Verilog-XL,用于Verilog仿真;NC-VHDL,用于VHDL仿真;NC-Sim,是Verilog/VHDL混合语言仿真工具
PSPICE
模拟与混合信号仿真的行业标准
PSpice Studio
PSpice
PSpice A/D
PSpice A/D Basics
技术特点:
@tinyhe
PSPICE著名的数/模混合电路仿真软件PSPICE著名的数/模混合电路仿真软件--------------------------------------------------------------------------------PSPICE模拟与混合信号仿真的行业标准PSpice仿真器是一个全功能的模拟和混合信号仿真器,它支持从高频系统到低功耗IC设计的任何电路。其高级功能允许用户进行“WhatIf”分析。PSpice强大的仿真引擎目前已方便地与OrcadCapture和ConceptHDL原理图输入工具结合在一起,使工程师可以方便地在单一的环境里建立设计、控制仿真及得到结果。PSpice产品包括:PSpiceStudio、PSpice、PSpiceA/D、PSpiceA/DBasics和PSpiceAdvancedAnalysisOption。PSpiceStudioIncludesallthefunctionalityofPSpice®simulatorwiththebuilt-incapabilitiesofPSpiceAdvancedAnalysis.PSpiceAfull-featuredsimulatorforseriousanalogdesigners.Sophisticated,internalmodelsallowyoutosimulateeverythingfromhigh-frequencysystemstolow-powerICdesigns.Drawontheexpansivelibraryofmodelstocreateoff-the-shelfparts,orcreatemodelsfornewdevices.Fullyexploretherelationshipsinyourdesignwith“whatif”scenariosbeforecommittingtofinalimplementation.PSpiceA/DAsophisticated,nativemixed-signalsimulatorandasupersetofPSpice.Allowsyoutosimulatemixed-signaldesignsofanysizecontaininganaloganddigitalparts.ThisincludeseverythingfromIGBTsandpulse-widthmodulatorstoDACsandADCs.Viewyoursimulationresultsinbothanaloganddigitalfromthesamewindowandonthesametimeaxis.PSpiceA/DBasicsAnentry-level,mixed-signalsimulationtoolidealforsimulatingsimple,basicanalog,orbasicmixed-signaldesigns.PSpiceA/DBasicsimposesnolimitsoncircuitsizeandperformsfunctionalsimulationofdigitalpartsinmixed-signalsimulationsallowingyoutoperformallthebasicPSpiceanalyses.PSpiceAdvancedAnalysisOptionPSpiceAdvancedAnalysisisanewproductfromCadencefeaturingtechnologyadaptedfromourAnalogWorkbenchproduct.Asanadd-onoptiontoPSpiceorPSpiceA/D,PSpiceAdvancedAnalysisprovidesaunifiedenvironmentfortakingdesignsfurther–improvingtime-to-marketperformanceandtheoverallqualityofyourdesignwhilekeepingoperatingcostsincheck.Pspice/PspiceA/D介绍对于仿真技术目前最流行是是以美国伯克利分校开发的Spice为核心的仿真软件,而以Spice为核心开发的最好的仿真软件就是OrcadPspice,它之所以流行就是因为它能很好的运行在PC平台上且能很好的进行模拟数字混合信号的仿真,而且能解决很多的设计上的实际问题。目前全世界的的仿真市场OrcadPspice占整个市场分额的82%(数据来源Dataquest,Dataquest是世界上最具权威的市场数据统计公司);另外一种仿真软件是非Spice为核心的其他专门电路及系统级的仿真软件,它相对于Spice为核心的仿真软件能解决超大(晶体管数超过5万)规模的电路因瞬态或DC分析不收敛导致错误结果或存储器溢出等在电路中极少碰到,但又在设计理论电路中又存在问题,同时也提高了仿真速度。这样的仿真软件的价格很高其使用的平台基本上都是UNIX平台;使用非常困难。除了那些具有世界上领先开发水平的单位才会购买,一般很少有单位会为其投资。PSPICE仿真器在1985年第一次出现后,经历了不断的增强和改造,已经被成千上万的工程师试验和证实;PSPICE是为严肃的模拟和混合信号设计而特性化的仿真器。使用其灵活的内部模型,用户可以仿真包括从高频系统到低功耗IC设计的任何模拟系统,用户可以使用数据表创建新器件的模型。技术特点:u使用功能强大的OrcadCapture或者CAPTURE/CIS输入用户的设计;u可以方便地将PSpice原理图编辑器创建的PSpice设计导入到OrcadCapture—PSpice环境中;u在OrcadCaptureCIS中启动交互式图形化PSpice激励编辑器,定义和预览激励特性;u访问可用参数描述的内置功能,或者用鼠标手工绘制分段性信号,创建任意形状的激励;u创建多个仿真剖面,并保存到CaptureCIS的项目管理器中,用户可以再次调用,并对同一电路运和不同的仿真;uPspiceA/D自动识别A到D和D到A连接,并插入接口了电路和电源,进行恰当的处理;u模拟和事件驱动数字仿真综合引擎提高了仿真的速度,而不会降低精度;u图示波形分析器在同一个时间轴上混合地显示模拟和数字仿真结果;u可直接查看节点电压、管脚电流和单个器件的功率损耗或噪声分布;u通过高级的参数、蒙特卡罗和最坏情况分析显示元器件变化时电路行为的改变;u创建绘图体模板,使用它们可以很容易地完成复杂测量,只需在原理图中期望的管脚、网络和器件上放置标志即可;u可以绘出电路电压、电流和功率损耗及其复杂函数,包括幅频相位伯特图和小信号特性的微分;u使用参数、蒙特卡罗和最坏情况分析,在多次运行中改变元件的数值,可以快速地得到一簇波形结果;u准确的内部模型,包括常用的R,L,C和二极管和晶体管,另外还有:内置IGBTs;7种MOSFET模型,包括工业上标准的BSIM3V3.1和EKV2.6模型;5种GaAsFET模型,包括Parker-Skellern和TriQuintTOM-2模型;带饱和性磁滞的非线性磁性模型;合并了延迟、反射、损耗、消散和串扰的传输线模型;数字元件,包括带有模拟I/O模型的双向传输门;u器件公式开发工具包允许建立PSPICE能够使用的新的内部模型公式;u模型库可能选择产自北美、日本和欧洲的16000个模拟和混合器件的模型;同时可从www.pspice.com下载大部分器件及厂家提供的Spice模型(大约有50多万个型供下载)。u使用带有各种宏模型的复杂器件,包括运算放大器、比较器、调节器、光耦、ADC、DAC等;u直接从网上下载各个厂家提供的最新器件仿真模型;uPSPICE模型编辑器,可直观地指导用户快速实现提取过程,器件的特性曲线给用户提供快速的图形反馈;u使用数字行为建模创建代表内部状态和管脚到管脚延迟的布尔表达式;u使用PSpice优化器自动调整电路,可自动调节电路参数的数值,改善模拟电路的性能,或者将电路性能匹配到某一数据曲线;并能将参数自动后向注释到Capture环境中;u从标准的测量函数中选择指标,如带宽、超调、上升时间和中心频率,或者使用性能分析向导创建自定义测量函数;u为有经验的器件物理工作者提供器件公式开发工具包(DEDK),用来开发任何器件模型;NC-DESKTOPSIMULATORS:High-qualityandreliabledesktopsimulationCadenceVerilog®andVHDLsimulationsolutions,alongwithNC-SimDesktopsimulatorsbringqualityandreliabilitytotheengineer’sworkbench.Asfull-featuredversionsoftheworld’sfastestsimulatortools,CadenceNC-SimDesktopsolutionsareidealforengineeringteamswhowanttoleveragetheperformanceandcapacitycreatedtovalidatemulti-milliongatedesigns.Formorethanadecade,Cadencesimulatorshaveservedasthestandardintheelectronicdesignandproductindustry.Todate,closeto50,000designshavebeensuccessfullycompletedusingCadencesimulators很好的Verilog/VHDL仿真工具,其中NC-Verilog的前身是著名的Verilog仿真软件:Verilog-XL,用于Verilog仿真;NC-VHDL,用于VHDL仿真;NC-Sim,是Verilog/VHDL混合语言仿真工具
你好
我想要ocad10.0,
可是我登陆不了21ic的ftp,请告诉我怎么能下载?
h21gf@netease.com
我想要ocad10.0,
h21gf@netease.com
