GTS1801
Product DescriptionThe GTS1801/G1801 ac-coupled Hall effectgear-tooth sensors are monolithic integratedcircuits that switch in response to changingdifferential magnetic fields created by movingferrous targets. These devices are ideal foruse in non-zero-speed, gear-tooth-basedspeed, position, and timing applications suchas in anti-lock braking systems, transmissions,crankshafts and so on.The GTS1801/ G1801, when coupled with aback-biasing magnet, can be configured toturn ON or OFF with the leading or trailingedge of a gear-tooth or slot. Changes in fieldson the magnet face caused by a movingferrous mass are sensed by integrated Halltransducers and are amplified by erroramplifier. The ac-coupled amplifier sensingdesign provides immunity to radial vibrationwithin the devices’ operating air-gaps.Steady-state magnet and system offsets are
eliminated using a band-pass filter. This filteralso provides relative immunity to interferencefrom RF and electromagnetic sources. Theinternal temperature compensation andSchmitt trigger circuitry minimizes shifts ineffective working air gaps and switch pointsover temperature, allowing operation to lowfrequencies over a wide range of air gaps andtemperatures.Each Hall-effect digital Integrated circuitincludes a voltage regulator, a quadraticHall-effect sensing element, temperaturecompensating circuitry, an error amplifier,band-pass filter, Schmitt trigger, and an open-
我司供应同步、异步升压,降压IC(DC-DC./AC-DC.),LDO。稳压IC,充电IC,音频IC,功放,MOS,二三极管,LED驱动,时钟IC,电路检测,传感器,陀螺仪,开关器件,防雷,背光驱动,视频监控,单片机,存储,光电子,仪器仪表,,通讯IC。调频调幅,矩阵开关,触摸IC,。IGBT. 收音IC 马达驱动 公司成立于2006年,现已发展成为中国zui da的电子元器件供应平台,代理国内各大品牌IC,与IC原厂直接合作。进口IC优势渠道商。保质量,价格优惠。品质打动客户,服务感动客户。
公司采用先进的ERP、商品条码、OA、CRM系统管理日常营运,为客户提供快捷、准确、高效的服务。
强势代理品牌:
航天民芯禾芯微 芯朋微嘉兴禾润华晶友旺顺芯
芯海 芯龙 圣邦微 芯地微 纳芯微思瑞浦拓微方泰芯联
微盟 时代民芯 瑞盟奥莉生屹晶微 友达泰德矽力杰来颉LRC华太赛芯微 维攀微 安沛 硅动力芯景松木 海威 力芯微
普芯达 华润矽科 录华 日晟微 超锐微 加尔发天微 中微爱芯 techpoint杭州鑫芯 BCD
分销:
博通,合泰,富士通,锐迪科,昆天科,谱成,远翔,南麟,ST,TI,DIODES,WOLFSON,旺宏,昂宝,尔必达,博世,飞思瑞克等
QQ:125952234
13602525829
